81 GS1000L
I am having trouble getting this ol bike up and running. I have been thru the carbs and the gas tank is clean but she still wont stay running unless the choke is on. Then it is only at one speed and if I give it gas you can hear the carbs opening up but it will not bring up the rpms. Any Ideas on how to fix this problem. The bike has been sitting for several years in a garage.
[IMG]local://upfiles/265/964008077D9F4653B1F675B4A3AAD2CD.jpg[/IMG] |
RE: 81 GS1000L
sounds like one and or two things to me. either the intake boots have started to leak, or the pilot jet and/or pilot circuit have gummed up in the carbs.
I just resurrected my 850, and it had both problems. also the GSs are really touchy about the airbox and exhaust all being "airtight", the airbox sides and crossoever pipes are both suspect. Use a small piece of wire, I used a wire from a wire brush, and clear the pilot (aka idle) jet's tip, mine was just big enough to let light through. Ill try to answer any other questions I can for you, I would usually recommend www.thegsresources.com but apparently the sites down. hopefully soon itll be back up and working as there is a wealth of info there on the old GSs. |
RE: 81 GS1000L
Thanks I will check things again. I have checked the www.thegsresources.com site out this will help alot i think. I will let you know how it works out I would like to get this ol bike up and running again soon...
