HEADLIGHT PROBLEM
HEADLIGHT OUT?INSTALLED A NEW LIGHT,FUSES ARE GOOD,POWER TO HEADLIGHT RELAY,NO LOSE WIRES OR CORROSION IN HARNES BEHIND LIGHT,TURN SIGNALS,BRAKE AND RUNNING LIGHTS ALL WORK.ANYONE HAVE A SOLUTION?
ended up taking the 50 to the shop,a bad interup switch(shuts headlight off)while starting,was bad,they simply jumped the switch,headlight stays on now while starting,cost eighty bucks for labor,cheaper than a 155.00 handle bar switch
susuki_s83
Dec 8, 2007 12:46 AM
