-   -   How to remove Chain Grease? (https://suzukiforum.com/forum/general-motorcycle-tech-39/how-remove-chain-grease-227/)
GSXRBOY Nov 13, 2005 12:54 AM
What are the better products out there for removing chain grease from things like your rim or plastic parts??? Any guidelines to follow?
I was thinking of using Goo Gone but I know that can be bad if you leave it on something too long.
GSXRBOY Dec 8, 2005 06:17 AM
RE: How to remove Chain Grease?
FYI Goo Gone works great! Just have to make sure I get the goo gone off so it doesn't sit there and damage my baby.
Patrick Dec 8, 2005 01:32 PM
what about tar remover?
sjordan01 Sep 27, 2006 04:33 PM
Goo Gone gets nearly anything off any surface. It also contains xylene, a very nasty health hazard. I've had good results using citrus based degreasers.
Weezee Dec 27, 2006 11:29 PM
I would use a citrus based cleaner myself, I have found plexas works pretty good on chain grease it is also real good on the frame and wheels
DIESEL Nov 21, 2007 03:34 PM
SPRAY A LITTLE WD 40 ON A CLEAN RAG AND WIPE IT OFF. WORKS WELL ON PLASTICS AND RIMS. USE THE WD 40 STRAIGHT ON THE CHAIN TO CLEAN IT . THEN WIPE IT WITH A RAG.
suzuki man Dec 8, 2007 01:08 PM
take the chain of and soak it in a bowl of petrol. (gasoline) since petrol is oil based it will not de-lubricate the chain and once removed from the bowl, the petrol will evaporate and you can regrease or oil. don't waste your money on expensive cleaners... you'll find it works a treat and it also removes tar if applied with a rag, wash off with ordinary washing up liquid.
pete600 Mar 4, 2009 09:20 AM
No don't do that :eek: Definately stay well away from petrol when cleaning your chain! It's great in that it'll make it look nice and shiny, but there's a danger it'll completely ruin the O-ring/X-rings inside the chain meaning you'll need a new chain (and sprockets too).
Haynes manual says if you want to take the chain off to clean it then use something with a high flash point (not petrol) such as kerosene or paraffin. I've used paraffin on mine which worked OK but I've by far had the best results using WD-40 and an electric toothbrush of all things, with the chain still on the bike.
