suzuki engine changes
Hi,
The GS750 engine will not fit in the GS1000 frame.
If you are taking shafties, the 850G engine will fit in the 1000G frame and vice-versa. Take care to move the necessary driveline parts too. IIRC, if you move an 850 motor into a 1000 frame (can't you find another 1000 motor?) you will need some parts from the 850 U-joint that connect it to the 1000's drive shaft.
If you have a 1000E (chain drive), there was no 850 chain drive from Suzuki.
For lots more info on these great GS bikes, visit http://www.thegsresources.com and the forum at http://www.thegsresources.com/_forum .
BassCliff
BassCliff
