2003 GSXR 600 ELECTRICAL??
Old Jun 18, 2007 | 05:14 PM
fuguy25's Avatar
Default 2003 GSXR 600 ELECTRICAL??
i have been tryin to fix my bike on my own.
i was riding it one day mid of winter.took it home cause of heavysnowing.2 weeks later i went out and tried to go on a ride and it just stopped.
the problems that have occured are...
1st-when you turn you key on,it does a systems check (thats where the RPM needle goes from 0 to red line),mine wont.the only thing that shows up on the cluster is the back lighting.no digital readings.
2nd-Fuel pump does not kick on.and since the pump does not kick on niether does the injectors.(took tank off and wired it with direct power and it does work.
Suzuki came up with the idea of combinding a fuel pump/blinker relay.(replaced it and after i got the $65 relay that wasnt the problem)
i got on e-bay,ordereda CDI ECU (main computer brain) and the problems still exsits.
after buying the brain,i was told that if i have lights on the bike that comes on,then it isnt the CDI.
I was also told it was the stator,so i took the cover off and it looked clean and no shavings or debre inside
i can put fuel directly in the throttle bodys and it will fire...i am having major withdrawls from riding!!! PLEASE HELP
i just happened to stumble upon this site by shear luck, i would be greatful if you could responde via e-mail
fuguy25@yahoo.com
or via MySpace
www.myspace.com/fuguy
I WOULD BE FOREVER GREATFUL WITH THE IDEAS AND THOUGHTS THAT MY GET ME BACK ON THE ROAD!! THANKS ALOT!
themytb
Jan 16, 2011 10:36 PM
gsxr 600 rider
5
Jan 24, 2008 11:09 AM
19Kilo
May 28, 2007 07:23 AM
bikz
Dec 9, 2006 03:29 PM
DaveyXXX
5
Jun 8, 2006 12:02 PM
