Hey all Newbie here,need help or manual for 01 rm 250
Old Nov 12, 2011 | 04:01 AM
notjoe's Avatar
Default Hey all Newbie here,need help or manual for 01 rm 250
So I just picked up this '01 rm 250 ,clutch cover is off,supposedly to replace leaking gaskets,clutch is missing 3 bolts and has one with bolt head snapped off shank of bolt,I plan to drill it out and replace,not sure of the torque required for install.
can anyone help?
Thank you for reading.
Paul
Old Nov 22, 2011 | 10:25 AM
mwatters's Avatar
can anyone help?
Paul
i don't konw the exact torque required, sorry! Did you check with your local suzuki dealership? they might be able to help. good luck and let us know how it goes!
Old Nov 23, 2011 | 05:35 AM
notjoe's Avatar
Default newb /thanks you for help
Thank you wmatters,I actually picked up manual as I began to notice more and more 'important' looking parts in bucket guy gave me with bike.also found,lastnight,stripped treads on main gear shaft,picked up 10mmx1.25 tap,hope it's the right one,based it on two bolts from aforementioned 'bucket-of-parts' that looked as if they might have once fit shaft.
will keep you posted on progress.
thanks again,
Paul
Old Feb 1, 2023 | 12:09 PM
gb6906's Avatar
according to my shop manual the locknuts are 36-50.5 lb/ft. Spring bolts are 8-9.5 and the union bolt is 14.5-18 lb/ft of torque
Wayne Ellison
Mar 5, 2017 11:43 AM
bona
Jan 14, 2016 05:53 PM
insideout87
May 7, 2010 01:23 PM
Lassie
Mar 26, 2009 02:10 PM
joshmundy
May 18, 2008 10:26 AM
