SF Help & Suggestion Center Need help with SF? Ask. Have a suggestion to better SF? Tell us here.
Swift 2010 fuel system
Old May 9, 2023 | 02:46 AM
minijem's Avatar
Default Swift 2010 fuel system
I have a Swift petrol and the manual says that the fuel operates for 2 seconds and stops. I have a problem with the ca and would like to know how the system decides to operate to pump more fuel. There is no regulator on the fuel rail and no return line. If I remove the pipe, with the ignition turned on, it pumps for a couple of seconds and stops. I would have thought that it would have kept on pumping as there is no pressure in the system. Does the engine have to be running for it to operate? How do I test the system? Thanks
Joemad
May 15, 2020 09:24 AM
maggiesmim
May 15, 2015 08:46 AM
maggiesmim
Apr 8, 2015 09:33 AM
maggiesmim
Mar 9, 2015 09:20 AM
eyeclose
Apr 27, 2014 08:06 PM
