aerio parts and problems
Old Dec 7, 2007 | 08:02 PM
AMDX1325's Avatar
Default aerio parts and problems
It seems that aerio lacks performance parts that can fit without modification, does anyone know any good performance products?
Only one I can find right now is the K&N air intake filter.
I'm alsolooking to upgrade suspension and brake system, stock aerio has a weak break and soft suspension for my liking.
I'm new to car modification, so advise please :-)
And my car is 5 years old, its starting to have fading paints, will a polish cure the fading paint? it looks right from distant, then when you look closer to the paint you'll see some fading, reflection is still there tho. I do wax my car but that only does it for a few days then the paint goes back to being pale again, especially the engine hood and top, as well as the rear, place where most sunlight hits.
Overall, I like the car, build quality is great, but the parts used could've been more durable, but its an economical car, how much more can I ask?
My Suzuki is a 2002 Aerio Sedan, Automatic, Red.
[IMG]local://upfiles/1723/BD7F2B48302648C99E6FE25A75FDACAF.jpg[/IMG]
Old Dec 7, 2007 | 08:57 PM
lomita's Avatar
Default RE: aerio parts and problems
Get yourself an underdrive pulley. They normally get about 100 ducks for one. Engine will wind up a little faster. Check www.aeriostyle.com forum or search for u/d pulley for details.
Old Dec 21, 2007 | 12:21 AM
chillinpapeSX's Avatar
I havn't seen much out there for our Aerio's but mostly the guys in PR trick out their Aerio's sweet. Mainly inside the cabin, some put Turbo kits but have to take them off after some time. Their's a short ram made by K&N but it's a pain in the *** since the sensor will go off due to the heat the engine produces.
I'd recommend a sway bar for the front and rear, short ram with a heat shild, 16 inch rims with some sticky tires, with the under drive pulley. You'll be good then, just to kick it up a notch replace front rotors with vented, replace suspention with a better one, last a Flowmaster system.
faiz
Apr 30, 2018 10:57 AM
Hanz
Jun 17, 2011 01:58 AM
4reyes
Dec 2, 2008 07:52 PM
Vashtie
Dec 26, 2007 04:49 PM
Yellowjacket01
Dec 1, 2005 03:35 PM
