Clutch Issue for a 2008 Suzuki Boulevard M50
Old Jul 4, 2025 | 05:29 AM
Carpelogan1967's Avatar
Default Clutch Issue for a 2008 Suzuki Boulevard M50
I was downshifting while approaching a stop sign. I thought at first I had shifted from 2nd to neutral but I hadnt. There was no odd noises or anything.
Now I can start the bike, shift into first- neutral ( nuetral light activates)- second-etc but there is no power to the rear tire.
Ive never had clutch or driveshaft issues. Fluids are good. Clutch assembly is functioning properly.
issues.
Before I start tearing into things does anyone have any
Old Apr 3, 2026 | 02:09 AM
fewedoqoned's Avatar
It sounds like your clutch is disengaging normally, but power isn’t reaching the rear wheel, which could point to a problem in the transmission or final drive rather than the clutch. Even if the clutch feels fine and fluids are good, internal gears or the output shaft could be damaged, or a chain/belt drive could have slipped. Double-check the chain or drive system first, then inspect the transmission for any signs of broken or stripped gears. A https://tropical-casino.com/ careful look before tearing it apart can save a lot of extra work.
Carpelogan1967
Jul 4, 2025 05:29 AM
Bradwhite94
Apr 11, 2024 09:56 PM
jcsjeepcrusier
Aug 9, 2019 09:59 AM
Reuben
Aug 9, 2019 09:52 AM
OntarioLes
Jun 1, 2019 07:25 AM
