Help electrical
My intruder 1400 it started once this year tried again and no power any where tested key has power intill I turn it on then no power any where ,I mean is power wire to switch is hot intill I turn it on then it goes dead don't understand
I think that it has either a battery problem or it would be a wiring problem. The battery or wiring is not bearing the load when you try to start your motorcycle. I was facing the same problm with my 2015 gsx s750. I visited my local mechanic who changed the wiring and installed the battery. It worked fine about that.
