Help electrical
Old May 28, 2022 | 08:38 PM
Adehartson's Avatar
Default Help electrical
My intruder 1400 it started once this year tried again and no power any where tested key has power intill I turn it on then no power any where ,I mean is power wire to switch is hot intill I turn it on then it goes dead don't understand
Old Sep 11, 2022 | 12:48 AM
RjMaan's Avatar
I think that it has either a battery problem or it would be a wiring problem. The battery or wiring is not bearing the load when you try to start your motorcycle. I was facing the same problm with my 2015 gsx s750. I visited my local mechanic who changed the wiring and installed the battery. It worked fine about that.
oldguy
Mar 11, 2021 09:29 AM
wernwilk
Aug 28, 2012 05:29 PM
2011suzukis40
Apr 6, 2012 08:50 PM
ljf0021
Dec 8, 2007 01:05 AM
tspot100
600, 750
Jun 15, 2007 05:45 AM
