suzuki rm 125 1996 no compression on kickstart
Old Jul 30, 2008 | 11:49 AM
jimcole198521's Avatar
Default suzuki rm 125 1996 no compression on kickstart
hi
i brought a suzuki rm 125 just over 2 weeks a go last week end it just died when i was riding it and wouldnt start off the kick or bumping it, i have noticed theres no compression in the kick start does any body no wat the problem is thanks alot jim
Old Dec 29, 2008 | 10:48 PM
codicur's Avatar
Default RE: suzuki rm 125 1996 no compression on kickstart
if there were no noises or if you didnt have it full throttle for a long period of time it sounds like you need to put a new ring in it to me no big deal its a normal 2 stroke thing but if you had it wide open for a while you probibly melted o hole in the piston take your plug out and check it for metal if there isnt any its prob just the ring.
Old Jan 29, 2009 | 10:46 PM
warto1's Avatar
ORIGINAL: codicur
ya it sounds like your top end blew. easy fix. my experience with a 2 stroke is when it runs better and better each and everytime u ride it, the top end is close to going out. also if u pull your plug as advised above check the color of the burned area. its best to check after being wide open asap even when its still hot but if u are white with lil to no carbon buildup you are running too lean on ur fuel/oil mixture and that will make your top end to go. that could be easily change by going with a bigger main jet in the carb.
nathanrm125
4
May 7, 2013 11:42 PM
don62
Jul 22, 2012 02:02 PM
stupidlogic
May 29, 2009 09:04 AM
codicur
Dec 30, 2008 11:49 AM
tsboy
Dec 27, 2006 10:50 PM
