94 dr 350 shifter wont rebound
Old 03-14-2012 | 10:04 PM
Walker350's Avatar
Default 94 dr 350 shifter wont rebound
The title says it all. After I remove the clutch cover to reseal due to a bad gasket, after its all back together the shifter will not rebound to position itself for the next gear. You must manually do it. The bike shifts through all the gears but its so annoying and is obviously not good. Any advice on what could be the cause?
Old 03-18-2019 | 02:41 PM
krivs388's Avatar
The pawls for the shift return might have spit out a spring or something like that. That would allow you to shift, but the shifter won't return to it's middle position. If you don't have a service or clymer manual, I'd definitey get one and take a look at the pawls. I just rebuilt the bottom end on my RMX 250 and those little springs in the pawls are a serious PITA. I've attached a pic with the mechanism and pawls from my RMX. I would think your DR has something similar.
Good Luck
arcare
03-18-2019 05:53 PM
Ryan Born
01-18-2013 10:29 AM
roachonius
Bandit 1200S
07-20-2011 12:19 PM
moses
05-19-2007 05:45 PM
JOEJAVA68
03-31-2007 02:27 PM
