XL7 2008 - Key stuck in ignition
Old Nov 11, 2011 | 01:56 PM
melkiades's Avatar
Default XL7 2008 - Key stuck in ignition
Hi there,
My local Suzuki dealer has had the car for a week now and they can't figure it out. Here's the problem:
- key stuck in ignition
- you can start the engine, you can shut it down too, but the key won't come out
- please don't suggest basic stuff like making sure it's on Park - we tried all that
- the dealer even changed the Solenoid (is that the cylinder?), to no avail
- I asked them to remove the entire cylinder and change the keys, he says that it's what he did by changing the solenoid but it doesn't make sense to me because when he had done that a few days ago he told me that I'd be using the same keys (??).
He now says that Suzuki is on the case and that they are suggesting a major electrical problem in the car.
Does that make any sense to you ?
Old Nov 27, 2011 | 11:07 AM
mwatters's Avatar
Originally Posted by melkiades
Hi there,
Sounds frustrating! I'm surprised the suzuki dealership is even having problems! I wish I had a solution for you, but I just wanted to say good luck, hope they get it figured out soon. What year is it?
Old Nov 28, 2011 | 06:58 AM
melkiades's Avatar
Hi mwatters,
Thank you for your reply. As I stated in my subject, it's a 2008. They finally got to fix it - after TWO weeks !! - and it had to do with the transmission. For some reason it wasn't going all the way into Park mode, thus blocking the key from getting out. They fixed it under warranty. Now the less amusing part is that they told me by brakes and pads were finished.
Do you know where I could find a good deal on good quality brakes and pads in Canada? I heard that you can find some amazing deals online.
Cheers,
Alain
Old Dec 11, 2011 | 08:59 PM
Rod Suzuki's Avatar
It's really annoying when you have a reasonably new car and it doesn't work properly. These kind of problems on Suzuki Parts are not very frequent at all. Hope it was just bad lucky and once it is fixed your car run nicely and smoothie. I'm from Australia and I don't know where you can find a good deal on Suzuki Services or parts in Canada, but I wish best of lucky for you
Old Jan 2, 2012 | 05:05 PM
michelsmith's Avatar
There is nothing other than the key cylinder itself that will keep the key from turning. A bad brake light fuse or battery can keep the shifter from coming out of park. There is anti theft built into the key cylinder but if you drove the car in then that should not be a issue. If the antitheft is truly active then the car has to be towed to a Suzuki dealer to be repaired. I seriously doubt any other shop would have the scan tool to get into the computer system of the car.
Loyal5
May 7, 2012 11:46 AM
stormcat
Jul 15, 2008 10:25 AM
diodisangue
Jan 20, 2008 03:27 PM
asosa
Aug 28, 2007 08:42 AM
daronj67
May 16, 2006 03:26 PM
