C50 Stalling out while in traffic or coming to lights.
Old Aug 30, 2022 | 11:25 AM
ATW22's Avatar
Default C50 Stalling out while in traffic or coming to lights.
Hello all, so I have the dreaded issue that I have heard and read a lot about on multiple forums. Bike runs great for 1st 20 minutes then starts stalling out while in traffic or coming to lights. Starts back up immediately but you have to give it a bit of gas then runs fine and then starts acting up. Had the work done at local shop and they let the bike run for 45 minutes in 92 degree weather and ran fine. drove it home and it started acting up "Stalling out while in traffic or coming to lights". Called the shop and let them know whats going on, they said to bring it back in as it must be something else. Let it run in my driveway for over an hour and the only thing I noticed is sometimes it will idle high and then go back down to normal maybe once or twice in the hour. otherwise purred like a kitten.
Now the fan does come on when it is supposed to while riding and at idle so I do not think it is overheating, however she does run hotter than most bikes I have ever owned. My 1st Suzuki cruiser and I am thinking it maybe my last if i can not get it figured out.
I ordered a set of coils as some say it solved the issue but I do not think its a fire issue, leaning more towards fuel (pump is pumping good).
2007 C50 27,000 miles
New Plugs
New Oil
New Coolant flushed
New Clutch
New Fuel Pressure Regulator
New Injectors
New Fuel Filter
Tank drained and cleaned
Valves just done, small tick but much better than it was
Any thoughts...
Old Jan 28, 2025 | 12:21 AM
keymac's Avatar
New Plugs
New Oil
New Coolant flushed
New Clutch
New Injectors
New Fuel Filter
Any thoughts...
Hey I have the same sort of problem starting with my C50. Dis you get any replies or help with sorting this out?
Old Jan 28, 2025 | 07:01 AM
ATW22's Avatar
Yes, I chased this issue and replaced more than I had to. Simply order the below off Amazon, bike runs 100 times better than new and NEVER stalls or gets hot anymore. If Amazon does not have it make sure you get one for 85C.
LANBAO Radiator Fan Thermo Switch 85℃ For Suzuki AN250 Burgman AN400 1999 2000 2001 2002 17680-33E00-000 17680-33E01-000
Rlwalker58
Sep 5, 2020 08:04 PM
Captain Dave
Mar 28, 2020 10:02 AM
gregsc50
Aug 9, 2019 09:50 AM
Rf900Flyer
Jul 21, 2006 01:09 PM
sdmsuzuki
Mar 7, 2006 09:18 AM
