Fuses in headlamp assembly
Old Jul 20, 2009 | 12:13 PM
Sturtw's Avatar
Default Fuses in headlamp assembly
My light bar stopped working in my 2008 Suzuki C50 and I assume it must be a fuse. Anybody know if there is an inline fuse in one of the connectors inside the headlamp assembly? The only fuses in the owners manual are the main fuse and the accessory fuse (ground) at the battery. Both check out OK. Any ideas?
Old Jul 23, 2009 | 07:32 AM
C90Rider's Avatar
I also have a C50 and put an aftrmarket light bar on it, I don't recall any in line fuses. It sounds too simple but I'd check grounds and connections to ensure that they are all tight.
ChuckG
Remember...Rubber Side down, Shiny Side up.
Old Aug 8, 2009 | 08:36 PM
Fargo_mikeR's Avatar
Default aftermarket light bar
I have a 2005 boulevard c90t, and my light bar quit working, too. I have checked all connections upto and including the wires behind main headlight. I see no inline fuses.My lightbar has switch to turn the lights on and off. The switch is fine.
I am told there are only 2 fuses on this bike.
Any suggestions?
Fargo_mikeR
sparkmaster123
Apr 13, 2011 11:31 PM
redcarwire
Jan 19, 2011 07:14 AM
skegbyrd
Feb 26, 2009 07:43 AM
jamesg
Jun 25, 2007 08:08 PM
kcblvdrider
Apr 17, 2005 01:48 PM
