bike dying
Old Aug 21, 2012 | 09:25 PM
m50lover's Avatar
Default bike dying
My bike is dying while riding. Only if i let throttle or rev it up. I just changed the battery so that not it. Any help will be great.
Old Aug 21, 2012 | 09:26 PM
m50lover's Avatar
Let off throttle. Sorry.
Old Aug 23, 2012 | 04:29 PM
gtcoder's Avatar
Default mine too
I bought my 2000 Marauder VZ800 in Oct-2012. It's my first bike. I bought the bike with 1,100 miles on it. I've put over 7,000 miles on it since then! The previous owner put Cobra pipes on it and lowered the idle to give it a lumpier idle sound. I was having the exact same problem that you described. The bike would cut out under hard deceleration, coming hard off the throttle, and in the middle of turns when I'd pull in the throttle. I dealt with it for awhile and then took it to a dealer thinking I needed a carb rebuild. Dealer recommended a carb tune up first and that worked. All they did was do an idle and mixture adjustment. The good news is that it solved the problem. Bad news is that I lost my lumpy idle and I now get regular backfires...guessing it's a little lean??
Hope that helps
Old Aug 24, 2012 | 08:29 AM
m50lover's Avatar
My bike is fuel injected but the fuel air mix is probable off. Being that i de baffledthe pipes. But that was about 2 years ago.
Larry Steve Delgado
Jan 18, 2012 10:44 PM
