C90 Ignition problem...
I've got an '05 Suzuki C90. I've replaced battery and it has a full charge. Getting VERY weak power to ignition. When I place my amp meter on the battery terminals I'm getting about 12.7 volts. If I place probes on the starter relay I'm getting 12.5 volts with the key off. As soon as I turn the key on the reading drops to about 2 volts. Fuel pump runs, barley, then stops and voltage drops to about 1.5 volts. I've checked the 30 amp fuse located on the relay and it is good...Any suggestions???
Check weather if the battery is gone week due to which it is not providing a proper volt.
Suzuki HID Kits
Suzuki HID Kits
Check out the cut outer or the dynamo. if still the take it to an local technician.
Performance Chip
Performance Chip
I am agree with volnut, you should have to check the battery that it will providing a proper volt, than check out the cable connection that it will gone a cut from anyside.
Misterx71uk
Jun 18, 2007 08:53 PM
sonicrocket76
Feb 6, 2006 06:46 PM
