clutch
Old Jun 8, 2021 | 12:15 PM
Djminert's Avatar
Default clutch
hi all. I have a 2003 SUZUKI INTRUDER VS800. I have no tension in the clutch. the bike has been sitting for 2 years. Hoping to get it up and running. I removed cover from master cylinder on handlebar. Fluid was milky. i removed fluid from master cylinder. added new fluid, now trying to bleed system. when i pull clutch lever several times, still no tension. i open bleeder valve and fluid does come out. i pull clutch lever several times again, still no tension, open bleeder valve and fluid comes out. fluid is fairly clean that is coming out of bleeder valve. do i have to keep doing this and eventually i will get tension on clutch lever, or do i have other problems? I have the Motorcycle book for my ride. been going by that. Any help will be appreciated.
tps
May 22, 2021 08:02 PM
mq13
Sep 23, 2017 09:21 AM
Kenny-rf9
Mar 15, 2011 10:06 PM
knugs78
May 9, 2009 01:59 AM
rockhauler2006
Apr 27, 2008 09:40 AM
