M50 battery discharging
Old May 5, 2009 | 05:47 PM
Dronzoid's Avatar
Default M50 battery discharging
I am new owner of 2005 M50. Good bike.
One problem - when I park without riding for two or three days, the battery discharges. It is a good battery, and I have in fact removed the positive terminal and checked with an ammeter for current draw.
With ignition OFF, there is a significant current draw, and I suspect a short in the system
Has anyone experienced this problem? Is there "most likely" location, or a systematic way of tracking down the short?
Old May 30, 2009 | 03:07 PM
MagicOPromotion's Avatar
did you perchance turn the key to the PARK position, when you removed the key?
When that happens, the tail light burning on the unattended bike will run down the battery.
Please do not ask me how I know this
_______
=== XRumer 5.0 Palladium RULEZ! ===
Old Jun 27, 2009 | 05:51 PM
Dronzoid's Avatar
Default M50 battery discharge
Thank you for any replies. I did in fact track down the problem myself. There is a great ganglion of wires which pass beside the left side of the forks. These wires are stressed each time the forks are turned, particularly badly when the forks are in the "parking lock" position. I found one wire which had the insulation worn away, which shorted against the back of the ignition key housing when the steering column was locked. It was relatively easy to find and correct once I started investigating.
Good bike
Old Aug 27, 2010 | 12:44 AM
kurtdaniel's Avatar
Check the ignition wire set,,something must have been mistakenly connected to it causing it to drain... need to check for voltage draw in the vehicle while shut off..
flhtcijohn
3
Aug 29, 2021 11:49 PM
KeithWfromLB
4
Oct 22, 2012 03:55 AM
redcarwire
Feb 27, 2009 09:52 PM
robinhood024
Sep 27, 2008 12:27 AM
chillinpapeSX
Mar 15, 2007 12:58 AM
