VS1400 Intruder need help
Old May 23, 2022 | 10:54 AM
Lizardlips529's Avatar
Default VS1400 Intruder need help
I've looked all over internet couldn't find an answer. My problem is when I try to start bike(squeeze clutch, in neutral, kickstand up) power clicks and idiot lights go off. Sounds like a fuse but none pop. Only way I can seems to fix problem it disconnect battery pull all 5 fuses from box above battery once i put them all back it and try again most times it starts right up and I have no issues. Next day sometimes same thing its not consistent and I don't want to get stuck at work with it.
It's weird that fuse doesn't pop. I haven't tried with clutch 3/4 out 1/2 out to see if it was clutch switch causing problem or if it is starter button itself. Was wondering if anyone else experiencsame issue
Harold Evans
Jul 8, 2024 11:20 PM
jcsjeepcrusier
Aug 9, 2019 09:59 AM
Jim
Oct 11, 2017 06:45 PM
sneek24
4
Jun 8, 2016 08:11 PM
rockhauler2006
Apr 27, 2008 09:40 AM
