gsxr 600 electrical
Old Jun 13, 2005 | 03:49 PM
gsxr 600 rider's Avatar
Default gsxr 600 electrical
can you help? pulling into the drive way our bike's electrical systems seemed funky...tac, speedometer etc. went out bike died then all of a sudden we had power again drove it up the drive way and that was it. bike wouldn't start again. The regulator was replaced and we got 600 miles out of it so far this year, the same thing happened again...any one ever run into this problem? would the altenator be killed at this point?? Help please
Old Jul 5, 2005 | 08:09 PM
Devildog1985's Avatar
Default RE: gsxr 600 electrical
Man if I could bother you to help me I'd be foever greatful, your problem sounds almost like the problem I have. do you have any troubleshooting tips I could go of of. My bike was running, then the next morning when I went to start it back up it wouldn't start back up. tried cleaning carbs and replaced plugs, I have spark and fuel, just don't have a bike that runs.
Old Jul 12, 2005 | 07:28 AM
GSXRBOY's Avatar
You have fuel/spark and it wont run???? Assuming you have spark then that should void almost any electrical problem out.
What exactly do you 2 mean when the bike doesn't start?
Does it crank and start to catch but won't fully start?
Does it crank with no sense of combustion?
Does it sit there with no cranking?
Is the engine hot when these problems occur?
Old Jul 12, 2005 | 11:13 AM
HI. No the bike will start and the bike will run. the battery isn't charging. Last year we went for a bike ride, came home and the gages droped and the bike sputtered then shut off...then started up again. The bike didn't run for a while after that I replaced the regulator this season we got 500+ miles out of if then the same thing happened. any thoughts?
Old Oct 10, 2007 | 02:40 PM
seewhite1's Avatar
your post was some time ago but i thought i would respond anyway. i'm having the same problem with my 2000 GSXR 600. riding down the road and the electrical stuff on the dash shuts off...(no horn, no high beam indicator light, no tacometer, no speedo, etc). let the bike sit for 30 minutes the first time and it started up. battery is only 2 months old (first battery lasted 7 years). rode the bike for another hour then it did it again. this time i waited 20 minutes and it started again. although i had to push start it as the battery didn't have enough juice to kick it over. let the bike sit over night and went riding the following day only to have the bike die again...this time only 5 minutes into the ride. battery was even weaker after 20 minute wait and wouldn't kick over. towed the bike home that day.
i'm assuming that the alternator is busted but wondered if figured out the problem.
Old Jan 24, 2008 | 11:09 AM
  #6
chenelle1000's Avatar
BIKE DONT HAVE ALTERNATORS, THEY HAVE RECTIFIERS WHICH CHARGES THE BATTERY WHILE YOU RIDE. AND THAT PROBLEM MY BE THAT YOUR BATTERY TERMINALS ARE LOOSE!!! THIS USUALLY HAPPENS WHEN YOU STUNT ALOT OR JUST DONT CHECK THEM OFTEN. THEY BIKE WILL USUALLY CUT OFF ON AN INCLINE OR IS YOU ROLL OVER A BUMP IN THE ROAD. CHECK IT OUT!
themytb
Jan 16, 2011 10:36 PM
fuguy25
Jun 18, 2007 05:14 PM
19Kilo
May 28, 2007 07:23 AM
DaveyXXX
5
Jun 8, 2006 12:02 PM
jimmy1731
Apr 20, 2005 03:12 PM
