1999 rm125 crank issuies
Old Dec 22, 2023 | 11:53 AM
jcalhoon077's Avatar
Default 1999 rm125 crank issuies
So i picked up a 1999 rm125 the other day for 500 that needed crank bearing's and to be put back together, i froze the bearings heated the case and dropped them in then i froze the crank and heated the bearing a little but when i put the crank in it locks up and wont turn, if u go past about a quarter inch gap between the crank and case it locks up, there are small scrapes on the crankcase like the crank is to big to fit all the way down and be able to spin freely, is this a thing?
Old Apr 11, 2024 | 09:54 PM
nicb's Avatar
Have you reassembled the crank case's or still split?
There is a very tight tolerance between crank and case, i had a, of all things the guide from the puller break and fall in between crank and case, it was less than .5mm yet caused the same issue, not found till i pulled apart again....
ulmanb
Apr 20, 2020 06:48 PM
PongTT1
Nov 12, 2018 04:21 PM
tino
May 11, 2012 05:46 PM
magillamike
Jun 28, 2010 10:53 PM
samolia
Nov 7, 2008 09:20 PM
