How to play AVI/MKV/WMV/FLV/MPG videos on Droid RAZR HD
Old Jan 31, 2013 | 08:16 PM
JhonBong's Avatar
Default How to play AVI/MKV/WMV/FLV/MPG videos on Droid RAZR HD
The introduction of the new Droid RAZR HD and RAZR Maxx HD represent Motorola’s first entry in the high-end smartphone market since it was acquired by Google. Motorola Droid RAZR HD comes with 4G LTE connectivity, much like the other two new RAZR phones . The battery that juices up this device is a 2530 mAh which, although isn’t too excellent, is definitely a notch above the 2500 mAh used in RAZR M.
If you have a glance on the main spec of the Motorola Droid RAZR HD, it's easy to find that RAZR HD video format is limited(VIDEO PLAYBACK:1080p HD Video, 30fps, MPEG4, H.263, H.264, VC-1, VP8). Thus, you will meet prolems that you can not play AVI files properly or missing audio when playing MKV videos on RAZR HD.
In order to successfully play AVI/MKV/WMV/FLV/MPG on Motorola Droid RAZR HD, you need to convert these video files to Motorola Droid Razr HD supported video formats in advance. In fact, it’s not a hard task. You can get the best Motorola Droid RAZR HD Video Converter to finish the conversion task. It’s an easy-to-use video converter that can always deliver what you need, with an easy intuitive interface. It can help you fast convert any video including but not limit to FLV, MOV, WMV, MTS, VOB, MKV, AVI, MPG, TiVo to Droid RAZR HD best video format MP4 at ultra fast speed in perfect audio/video sync.
Guide: Convert AVI/MKV/WMV/FLV/MPG to Motorola Droid RAZR HD MP4 video format
Step 1: Add video files
Click "Add” button to import the local video file or the folder containing several video files to this Motorola Droid Razr HD Video Converter. Also you can drag the video directly to this program.
Step 2: Select output format
Click on the dropdown menu of “Format” and choose Motorola > Motorola Droid RAZR H.264 Video (*.mp4) as the target format.
Step 3: Adjust video/audio settings
Tap the Settings icon and go the Profile Settings panel to adjust the video size, bitrate, frame rate, audio channel, etc as you want. You are advised to set the video size as 1280*720, video bitrate as 1500kbps.
Step 4: Convert videos to Motorola Droid RAZR HD
Click "Convert" button on the right bottom of main interface; start to convert videos to Motorola Droid RAZR HD at 5-6x faster speed with the CUDA/AMD acceleration support.
When the Motorola Droid Razr HD video conversion finished, you can import the converted video to your phone easily. Afterwards, you can enjoy AVI, MKV, WMV, MPG on Droid RAZR HD at ease.
Tip:
This Motorola Droid RAZR HD video converter can also work as the best video converter for Motorola RAZR HD for MKV, WMV, FLV, MOV, AVI, MTS converting. Learn more from Brorsoft Video Converter.
Related guides:
Fix Sony Xperia USB connection problems
Transfer DVD collections to Sony Xperia ion
How to play 1080p movies on Sony Xperia ion
Fast convert .mkv files to Nokia Lumia 920 MP4 format
Transfer MKV/AVI/MOV/FLV to MP4 for Sony Ericsson Xperia Arc S
Add HD videos (WMV/AVI/MKV/FLV/MPG) on Sony Xperia ion
Transfer music/video/photo files to Motorola DROID RAZR HD from PC
JhonBong
Mar 18, 2013 10:23 PM
JhonBong
Mar 6, 2013 08:37 PM
JhonBong
Jan 23, 2013 09:40 PM
JhonBong
Jan 16, 2013 07:42 PM
JhonBong
Jan 3, 2013 11:35 PM
