2007 C90 Turn Signals
Old 03-24-2017, 12:08 PM
perk_dp's Avatar
Default 2007 C90 Turn Signals
Can anyone tell me if a Right Rear Turn Signal Suzuki Part #35603-38AD0 is actually the same as Front Left Turn Signal Suzuki Part #35602-38AD0 even though they are different part numbers?
Old 10-25-2017, 08:59 PM
MrNimbles's Avatar
Hi Perk,
No, these two lights are different. The rear turn signals take 1156 single filament bulbs, and are 2 wire lights (only turn on for directional signal).
The front turn signals take 1157 dual filament bulbs, and are 3 wire lights (directional signal AND running lights)
That being said, I think the last time I had them off my bike they looked the same in appearance and mounting. I think you could probably use the front left on the rear right and only use 2 of the 3 wires (you will still need a 1157 bulb, the 1156 will not fit in the bulb holder) but not the rear light on the front.
However, I have not actually tried this. Anyone?
-MrN
2007 C90T
Old 03-10-2021, 07:13 PM
billdawg38730's Avatar
Default Turn signals
The front are two filement bulbs and rear are one filament The front have three wires and the rear have two wires.I’ve been thinking the same thing
Old 03-10-2021, 07:54 PM
Default Rear and front signals
I want to have rear running light on my C90T stock lights are on bike and I wanted to try putting same lights from front on rear but is not wired for three wires in rear ,,so I could have running lights on rear as well I know I will have to run an additional hot wire for run where to I run wire from fuse box r what??
Matt617
2
04-13-2021 01:25 PM
joeburris
01-01-2021 01:54 PM
el_capitan
4
03-27-2017 11:05 AM
gzzzr
08-15-2008 04:29 PM
suzukim50
05-03-2007 08:01 PM
Quick Reply: 2007 C90 Turn Signals
