How to remove Chain Grease?
Old Nov 13, 2005 | 12:54 AM
GSXRBOY's Avatar
Default How to remove Chain Grease?
What are the better products out there for removing chain grease from things like your rim or plastic parts??? Any guidelines to follow?
I was thinking of using Goo Gone but I know that can be bad if you leave it on something too long.
Old Dec 8, 2005 | 06:17 AM
GSXRBOY's Avatar
Default RE: How to remove Chain Grease?
FYI Goo Gone works great! Just have to make sure I get the goo gone off so it doesn't sit there and damage my baby.
Old Dec 8, 2005 | 01:32 PM
Patrick's Avatar
Administrator
what about tar remover?
Old Sep 27, 2006 | 04:33 PM
sjordan01's Avatar
Goo Gone gets nearly anything off any surface. It also contains xylene, a very nasty health hazard. I've had good results using citrus based degreasers.
Old Dec 27, 2006 | 11:29 PM
Weezee's Avatar
I would use a citrus based cleaner myself, I have found plexas works pretty good on chain grease it is also real good on the frame and wheels
Old Nov 21, 2007 | 03:34 PM
  #6
DIESEL's Avatar
SPRAY A LITTLE WD 40 ON A CLEAN RAG AND WIPE IT OFF. WORKS WELL ON PLASTICS AND RIMS. USE THE WD 40 STRAIGHT ON THE CHAIN TO CLEAN IT . THEN WIPE IT WITH A RAG.
Old Dec 8, 2007 | 01:08 PM
  #7
suzuki man's Avatar
take the chain of and soak it in a bowl of petrol. (gasoline) since petrol is oil based it will not de-lubricate the chain and once removed from the bowl, the petrol will evaporate and you can regrease or oil. don't waste your money on expensive cleaners... you'll find it works a treat and it also removes tar if applied with a rag, wash off with ordinary washing up liquid.
Old Mar 4, 2009 | 09:20 AM
  #8
pete600's Avatar
No don't do that Definately stay well away from petrol when cleaning your chain! It's great in that it'll make it look nice and shiny, but there's a danger it'll completely ruin the O-ring/X-rings inside the chain meaning you'll need a new chain (and sprockets too).
Haynes manual says if you want to take the chain off to clean it then use something with a high flash point (not petrol) such as kerosene or paraffin. I've used paraffin on mine which worked OK but I've by far had the best results using WD-40 and an electric toothbrush of all things, with the chain still on the bike.
Serenar
Dec 1, 2012 02:04 AM
henri
Oct 3, 2012 08:02 AM
coykiesaol
Jun 28, 2011 01:24 AM
dealrocker
Feb 17, 2010 05:36 AM
cantonm3
Jan 2, 2007 12:44 AM
